403 forbidden AP Tp-LInk
ttonchev
Hi ,
I have trouble accessing the AP.
Configuration of two vlan's with inter vlan routing is made and working .
10.0.1.0 Vlan10- PC etc ..
10.0.4.0 Vlan40- AP.
I have a L2 switch 2960 and cisco router 1841. I can access the Ap web interface only from VLAN40. When I try to acces the device from Vlan10 it gives me 403 Forbidden.
What could be the problem?
luis_cordova
Hi @ttonchev
As far as I know, TP-Link APs only allow web access to devices within the same network.
In your case, Vlan 10 corresponds to an external network to which the AP is located.
Within the TP-Link configuration you may find an option for remote administration in the system configuration.
thanks man. This solve my problem. Option remote management was the key. Thanks again :)
Hi @ttonchev
Remember to mark the correct answers as solved, because that helps other users with similar doubts
