el 09-05-2013 07:40 PM
HI,
I have installed my LMS 4.2 on the EXSi 5.0 recently,but today i find i can't log in the web ,it display as follows:
Forbidden
You don't have permission to access / on this server .
Additionally,a 403 Forbidden error was encountered while trying to use an ErrorDocument to handle the request.
for this scenriao,what's the reason?
could you help me ?
when i installed successful,i'm sure i can log in the web view.
my web browser is IE9.0.
¡Resuelto! Ir a solución.
el 09-05-2013 10:21 PM
Hi ,
Try to Regenerate SSL certificates: 1) Stop the daemons manager from CLI using /etc/init.d/dmgtd stop 2) Backup the following files found in /opt/CSCOpx/MDC/Apache/conf/ssl and then delete: server.crt server.csr server.key server.pk8 Under CLI go to "\opt\CSCOpx\MDC\Apache\" and then run ConfigSSL.pl by typed the following command on CLI. CSCOpx\MDC\Apache\perl configssl.pl -disable CSCOpx\MDC\Apache\perl configssl.pl -enable Then fill the certificate accordingly and restart daemons from CLI using netThanks-
start the daemon manager:
Afroz
Hi ,
Afroz
el 10-11-2013 07:52 PM
can you tell me how can i get into the cli page?
i login on the LMS from the console or through ssh, but i can't get these command?
el 10-11-2013 07:58 PM
Hi ,
you can get it through console or CLI as well. theh you need to type SHELL and then you should be able to run the command.
Thanks-
Afroz
el 10-11-2013 08:14 PM
ok, shell or shell_enable ?
i'll try it,thanks。
LMS02/sysadmin# ?
Exec commands:
application Application Install and Administration
clock Set the system clock
configure Enter configuration mode
copy Copy commands
debug Debugging functions (see also 'undebug')
delete Delete a file
dir List files on local filesystem
exit Exit from the EXEC
forceout Force Logout all the sessions of a specific system user
halt Shutdown the system
mkdir Create new directory
nslookup DNS lookup for an IP address or hostname
patch Install System or Application Patch
ping Ping a remote ip address
ping6 Ping a remote ipv6 address
reload Reboot the system
rmdir Remove existing directory
shell Access the shell by using the password
shell_enable Enable access to shell by setting password
show Show running system information
ssh SSH to a remote ip address
tech TAC commands
telnet Telnet to a remote ip address
terminal Set terminal line parameters
traceroute Trace the route to a remote ip address
undebug Disable debugging functions (see also 'debug')
write Write running system information
LMS02/sysadmin#
el 10-11-2013 08:42 PM
Hi ,
shell , if you know the password.
If you don't rememebe the shell paswword , you can reset it with shell_enable command.
Thanks-
Afroz
el 10-13-2013 10:14 PM
After regenerate SSl Certificates, it works very well, thank you very much !
and in my case, it need to execute the command in the following directory,
[LMS01/root-ade Apache]# cd bin
[LMS01/root-ade bin]# ./ConfigSSL.pl -disable
SSL is already disabled
[LMS01/root-ade bin]# ./ConfigSSL.pl -enable
Have a good day!
el 10-08-2017 06:01 AM
I have the same issue but can not type this command : ./ConfigSSL.pl -enable
How to solve it please?
el 10-09-2017 12:32 AM
how to take buckup and to delete.
el 04-02-2018 12:57 AM
HI AFROJ AHMAD
how do i backup i mean the cli command to backup the files?
Descubra y salve sus notas favoritas. Vuelva a encontrar las respuestas de los expertos, guías paso a paso, temas recientes y mucho más.
¿Es nuevo por aquí? Empiece con estos tips. Cómo usar la comunidad Guía para nuevos miembros
