4506e
vishalpatil86
hi,
does cisco 4506 e support nating?
ccube
Check the Network Address Translation Catalyst Switch Support Matrix on cisco.com.
Per this document, this is not currently supported via IOS alone. If you have a AGM (access gateway Module) with IOS12.2.13t or later on this module, then NAT support is available.
Hth,
Cary
