04-11-2012 01:33 AM
I've installed latest CNA version (5.7(5)).
I'm trying to add our 4510E to community, but in CNA, after find the device, it appears a message "unsupported device".
If I connect to 4510 with a browser, I can manage it, and the first link in page is "Cisco Network Assistant", that send to a CNS download page.
Now I use
ip http authentication enable
bacause if I use
ip http authentication aaa
I can't access the switch (in log it appears a login error, using same credentials used to login in ssh or console).
Any suggestions will be appreciated.
Daniele
04-11-2012 09:02 AM
I usually use "ip http aaa authentication local" (although the aaa option should work assuming your aaa server is otherwise setup correctly).
I'm not sure that "ip http authentication enable" is a valid syntax.
04-13-2012 03:43 AM
Thanks for your replu Marvin.
I'm using "ip http authentication enable" and it works, using enable password and username field blank.
But in all other switch I'm using "ip http aaa authentication" and I authenticate through tacacs, and it works.
Only into 4500 it doesn't work.
Any other suggestion will be appreciated.
Daniele
