6500s missing Module Information
david.fernandes
Running LMS 3.2 on a Windows 2003 box. I've noticed in trying to run a report on various module types that the 6500s are missing descriptive module information. For example, the below is a copy of the Module information section on the Detailed Device Report which is missing the serial number information.
I've checked this across several 6500s and the same behavior appears across almost all of them. Any ideas on what's going on here?
Module Information
Module Index          Parent Index          Parent Type          Slot Number
Description          Serial Number          Vendor Type          Model Name          Physical
Entity Name          Slot Configuration          Manufacturer Name
Operational Status          HW Version          SW Version          FW Version
Number of Slots          Number of Ports          Multiservice          Inline Power Capable
Hardware Encryption          Module IP Address          Additional Status
Admin Status          Reset Reason          Unique Device Identifier
8          0          chassis          1          48-port 10/100/1000 RJ45 EtherModule          0
CardType(4093)                                                  OK          1.6          8.4(1)
0          48          false          false
PID : 48-port 10/100/1000 RJ45 EtherModule VID : 1.6 SN : 0
9          0          chassis          2          48-port 10/100/1000 RJ45 EtherModule          0
0          48          false          false
10          0          chassis          3          48-port 10/100/1000 RJ45 EtherModule          0
0          48          false          false
11          0          chassis          4          48-port 10/100/1000 RJ45 EtherModule          0
CardType(4093)                                                  OK          2.3          8.4(1)
0          48          false          false
PID : 48-port 10/100/1000 RJ45 EtherModule VID : 2.3 SN : 0
12          11          module          2          IEEE Voice Daughter Card          0
CardType(4074)                                                  OK          2.3
0          0          false          false
PID : IEEE Voice Daughter Card VID : 2.3 SN : 0
13          0          chassis          5          Supervisor Engine 32 8GE          0
CardType(4079)                                                  OK          4.5
12.2(18r)SX9                    0          9          false          false
PID : Supervisor Engine 32 8GE VID : 4.5 SN : 0
14          13          module          0          Policy Feature Card 3          0
CardType(693)                                                  OK          2.3
0          0          false          false
PID : Policy Feature Card 3 VID : 2.3 SN : 0
15          13          module          1          Cat6k MSFC 2A daughterboard          0
CardType(4081)                                                  OK          4.0
12.2(17r)S6                    0          0          false          false
PID : Cat6k MSFC 2A daughterboard VID : 4.0 SN : 0
7 Replies 7
Joe Clarke
What version of code are these switches running?  What do you get when you walk entPhysicalSerialNum from one of these switches?
These 6500s have WS-SUP32-GE-3B running some flavor of SXI (SXI2, SXI2a, SXI3, SXI4a, SXI5).
When I walk from Ciscoworks one of these devices there is serial number information back in the response:
The following is a SNMP walk of device 172.28.248.141 starting from .1.3.6.1.2.1.47.1.1.1.1.11
SNMP Walk Output
.1.3.6.1.2.1.47.1.1.1.1.11.1 = STRING: SMG*******R
.1.3.6.1.2.1.47.1.1.1.1.11.2 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.3 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.4 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.5 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.6 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.7 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.8 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.9 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.10 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.11 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.12 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.13 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.14 = STRING: DCH*******6
.1.3.6.1.2.1.47.1.1.1.1.11.15 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.16 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.17 = STRING: SNI*******K
.1.3.6.1.2.1.47.1.1.1.1.11.18 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.19 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.20 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.21 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.22 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.27 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.28 = STRING: SNI*******8
.1.3.6.1.2.1.47.1.1.1.1.11.29 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.30 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.31 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.32 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.33 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.38 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.39 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.40 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.41 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.42 = STRING: SMT*******4
.1.3.6.1.2.1.47.1.1.1.1.11.43 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.44 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.45 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.46 = STRING: SMT*******8
.1.3.6.1.2.1.47.1.1.1.1.11.47 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.48 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.49 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.50 = STRING: SMT*******5
.1.3.6.1.2.1.47.1.1.1.1.11.51 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.52 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.53 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.54 = STRING: SMT*******3
.1.3.6.1.2.1.47.1.1.1.1.11.55 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.56 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.57 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.58 = STRING: SMT*******3
.1.3.6.1.2.1.47.1.1.1.1.11.59 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.60 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.1000 = STRING: SAL*******Y
.1.3.6.1.2.1.47.1.1.1.1.11.1001 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.1002 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.1003 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.1004 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.1005 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.1006 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.1007 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.1008 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.1009 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.1010 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.1011 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.1012 = STRING: SAL*******9
.1.3.6.1.2.1.47.1.1.1.1.11.1013 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.1014 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.1015 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.1016 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.1017 = STRING: SAL*******A
.1.3.6.1.2.1.47.1.1.1.1.11.1018 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.1019 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.1020 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.1021 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.1024 = STRING: FNS*******Z
.1.3.6.1.2.1.47.1.1.1.1.11.1033 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.1034 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.1037 = STRING: FNS*******T
.1.3.6.1.2.1.47.1.1.1.1.11.1046 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.1047 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.1050 = STRING: FNS*******M
.1.3.6.1.2.1.47.1.1.1.1.11.1059 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.1060 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.1072 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.1073 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.1085 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.1086 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.1098 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.1099 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.1111 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.1112 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.1124 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.2000 = STRING: SAL*******0
.1.3.6.1.2.1.47.1.1.1.1.11.2001 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.2002 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.2003 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.2004 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.2005 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.2006 = STRING: SAL*******C
.1.3.6.1.2.1.47.1.1.1.1.11.2007 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.2008 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.2009 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.2010 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.2011 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.2012 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.2013 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.2014 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.2015 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.2016 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.2017 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.2018 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.2019 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.2020 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.2021 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.2022 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.2023 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.2024 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.2025 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.2026 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.2027 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.2028 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.2029 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.2030 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.2031 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.2032 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.2033 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.2034 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.2035 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.2036 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.2037 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.2038 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.2039 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.2040 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.2041 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.2042 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.2043 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.2044 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.2045 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.2046 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.2047 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.2048 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.2049 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.2050 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.2051 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.2052 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.2053 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.2054 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.2055 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.2056 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.2057 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.3000 = STRING: SAL*******9
.1.3.6.1.2.1.47.1.1.1.1.11.3001 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.3002 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.3003 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.3004 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.3005 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.3006 = STRING: SAL*******7
.1.3.6.1.2.1.47.1.1.1.1.11.3007 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.3008 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.3009 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.3010 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.3011 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.3012 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.3013 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.3014 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.3015 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.3016 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.3017 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.3018 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.3019 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.3020 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.3021 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.3022 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.3023 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.3024 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.3025 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.3026 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.3027 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.3028 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.3029 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.3030 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.3031 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.3032 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.3033 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.3034 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.3035 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.3036 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.3037 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.3038 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.3039 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.3040 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.3041 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.3042 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.3043 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.3044 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.3045 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.3046 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.3047 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.3048 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.3049 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.3050 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.3051 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.3052 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.3053 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.3054 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.3055 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.3056 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.3057 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.4000 = STRING: SAL*******F
.1.3.6.1.2.1.47.1.1.1.1.11.4001 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.4002 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.4003 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.4004 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.4005 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.4006 = STRING: SAL*******A
.1.3.6.1.2.1.47.1.1.1.1.11.4007 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.4008 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.4009 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.4010 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.4011 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.4012 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.4013 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.4014 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.4015 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.4016 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.4017 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.4018 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.4019 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.4020 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.4021 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.4022 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.4023 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.4024 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.4025 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.4026 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.4027 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.4028 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.4029 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.4030 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.4031 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.4032 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.4033 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.4034 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.4035 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.4036 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.4037 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.4038 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.4039 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.4040 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.4041 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.4042 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.4043 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.4044 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.4045 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.4046 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.4047 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.4048 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.4049 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.4050 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.4051 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.4052 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.4053 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.4054 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.4055 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.4056 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.4057 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.5000 = STRING: SAL*******A
.1.3.6.1.2.1.47.1.1.1.1.11.5001 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.5002 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.5003 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.5004 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.5005 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.5006 = STRING: SAL*******F
.1.3.6.1.2.1.47.1.1.1.1.11.5007 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.5008 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.5009 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.5010 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.5011 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.5012 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.5013 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.5014 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.5015 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.5016 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.5017 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.5018 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.5019 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.5020 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.5021 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.5022 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.5023 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.5024 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.5025 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.5026 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.5027 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.5028 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.5029 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.5030 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.5031 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.5032 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.5033 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.5034 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.5035 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.5036 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.5037 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.5038 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.5039 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.5040 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.5041 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.5042 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.5043 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.5044 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.5045 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.5046 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.5047 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.5048 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.5049 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.5050 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.5051 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.5052 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.5053 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.5054 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.5055 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.5056 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.5057 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.6000 = STRING: SAL*******5
.1.3.6.1.2.1.47.1.1.1.1.11.6001 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.6002 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.6003 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.6004 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.6005 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.6006 = STRING: SAL*******S
.1.3.6.1.2.1.47.1.1.1.1.11.6007 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.6008 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.6009 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.6010 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.6011 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.6012 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.6013 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.6014 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.6015 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.6016 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.6017 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.6018 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.6019 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.6020 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.6021 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.6022 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.6023 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.6024 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.6025 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.6026 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.6027 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.6028 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.6029 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.6030 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.6031 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.6032 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.6033 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.6034 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.6035 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.6036 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.6037 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.6038 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.6039 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.6040 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.6041 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.6042 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.6043 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.6044 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.6045 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.6046 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.6047 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.6048 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.6049 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.6050 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.6051 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.6052 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.6053 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.6054 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.6055 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.6056 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.6057 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.7000 = STRING: SAL*******B
.1.3.6.1.2.1.47.1.1.1.1.11.7001 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.7002 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.7003 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.7004 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.7005 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.7006 = STRING: SAL*******8
.1.3.6.1.2.1.47.1.1.1.1.11.7007 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.7008 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.7009 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.7010 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.7011 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.7012 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.7013 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.7014 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.7015 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.7016 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.7017 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.7018 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.7019 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.7020 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.7021 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.7022 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.7023 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.7024 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.7025 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.7026 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.7027 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.7028 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.7029 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.7030 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.7031 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.7032 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.7033 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.7034 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.7035 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.7036 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.7037 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.7038 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.7039 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.7040 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.7041 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.7042 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.7043 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.7044 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.7045 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.7046 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.7047 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.7048 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.7049 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.7050 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.7051 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.7052 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.7053 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.7054 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.7055 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.7056 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.7057 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.8000 = STRING: SAL*******S
.1.3.6.1.2.1.47.1.1.1.1.11.8001 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.8002 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.8003 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.8004 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.8005 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.8006 = STRING: SAL*******2
.1.3.6.1.2.1.47.1.1.1.1.11.8007 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.8008 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.8009 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.8010 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.8011 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.8012 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.8013 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.8014 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.8015 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.8016 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.8017 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.8018 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.8019 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.8020 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.8021 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.8022 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.8023 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.8024 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.8025 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.8026 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.8027 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.8028 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.8029 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.8030 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.8031 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.8032 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.8033 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.8034 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.8035 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.8036 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.8037 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.8038 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.8039 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.8040 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.8041 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.8042 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.8043 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.8044 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.8045 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.8046 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.8047 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.8048 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.8049 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.8050 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.8051 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.8052 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.8053 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.8054 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.8055 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.8056 = STRING:
.1.3.6.1.2.1.47.1.1.1.1.11.8057 = STRING:
ENTITY-MIB inventory must be failing and RME is falling back to the CISCO-STACK-MIB.  What version of RME do you have?
Resource Manager Essentials4.3.127 Sep 2009, 16:07:09 EDT
You should try updating to RME 4.3.2 (LMS 3.2 SP1) as there were a lot of inventory collection bugs fixed.  After doing that, run a full inventory collection.  If the serial numbers are still missing, open a TAC service request using the Open Service Request link in this thread.  Additional inventory collection debugging can be done to see why the ENTITY-MIB collection is failing.
Thanks Joe. I must have missed the software release notice for that one. Just to make sure I'm not missing anything else, were there any other software releases for the below? Also, assuming there are, is there a recommended order in applying them?
Bundle Name Version Installed Date
1.LMS3.226 Aug 2009
Product Name Version With Patch Level Installed Date
1.Campus Manager5.2.121 Nov 2009, 17:50:29 EST
2.CiscoView6.1.926 Aug 2009, 10:04:33 EDT
3.CiscoWorks Assistant1.2.026 Aug 2009, 10:04:33 EDT
4.CiscoWorks Common Services3.3.026 Aug 2009, 10:04:33 EDT
5.Device Fault Manager3.2.026 Aug 2009, 10:04:34 EDT
6.Integration Utility1.9.026 Aug 2009, 10:04:34 EDT
7.Internetwork Performance Monitor4.2.026 Aug 2009, 10:04:34 EDT
8.LMS Portal1.2.026 Aug 2009, 10:04:35 EDT
9.Resource Manager Essentials4.3.127 Sep 2009, 16:07:09 EDT
The LMS 3.2 SP1 mega-patch will take care of updating everything.  After doing that, apply all of the latest device updates.  Don't forget to install the patch described at https://supportforums.cisco.com/docs/DOC-16806 in order to have device update capabilities work within LMS after this week.
