6509 Sup-2T management through CMP interface
g.fabre
Hello
We acquired recentlty a new Cisco 6509 with Sup-2T supervisor card
My question is the following :
   we have a management subnet on a Copper-based switch; we manage all equipments through this network.
   I planned to configure the management interface on the 6509 to connect this switch & monitor the VSS through it
   However, since it is a CMP interface, most of the actions (SNMP, IOS upgrade.. won't be possible through this link)
   Moreover, I don't think LMS would be able to get the configuration through it (except by configuring a script running "attach" command & show run
Is there something I miss or must I add another interface of the Catalyst to this network (the problem being that I have no copper line card)
I would appreciate your inputs.
Thanks in advance !
lacirasella
did you find out how to reach the CMP since your request?
hi
we finally used a GLC-T SFP on the 1G Supervisor port to connect the switch & configured the management vlan on this interface too.
the funny thing is that we used a temporary solution with SFP+ 10G-LR in order to connect the management switch before we were able to free a 1G port :-)
