6509 syslog not working
Eric Lindsey
I have a 6509 on my network and also have LMS4.1 for management. My 6509 is listed in my lms as a device. The config is in LMS. But I am not getting any syslog messages in LMS for my 6509. I have logging turned on and I have my LMS server listed in the config using the logging IP address command. What could be missing that would prevent the syslog messages from showing up in LMS. I have other devices that send syslog messages fine.
kcnajaf
Level 7
Level 7
Hi Eric,
Hope you have set following.
logging on
logging facility syslog
logging trap <>
logging source-interface <>
logging <>
If still this is not working could you share the output of "show logging"
Najaf
Please rate when applicable or helpful !!!
kcnajaf
Level 7
Level 7
Hi Eric,
logging on
logging trap <>
logging <>
Najaf
Eric Lindsey
You nailed it. It was the source-interface command that did the trick.
