a Q about sfp compatibility
baselzind
Frequent Contributor
please if someone can tell me if the attached picture is compatible with my WS-C4507R+E switch module below
ports:12
card type:10GE SFP+
model:WS-X4712-SFP+E
 - Not any foreign sfp will work for 'pure' cisco info's go here : https://tmgmatrix.cisco.com/ , if 'external' sfp's are being used and it does not work, you may try configuration commands such as
service unsupported-transceiver  and
no errdisable detect cause gbic-invalid
             (provided these commands are available on your platform)
 M.
-- ' 'Good body every evening' ' this sentence was once spotted on a logo at the entrance of a Weight Watchers Club !
7 Replies 7
Leo Laohoo
WS-X4712-SFP can support SFP &/or SFP+:
SFP+ and SFP can be used simultaneously on the same line card without any restrictions
baselzind
thank you but what about the sfp in the picture? is its model compatible? does my line card only support certain models of sfp? or any sfp would work?
 M.
baselzind
thank you but what about if I use a cisco sfp on my switch and on a ibm server we use an ibm sfp, would a cisco sfp work with non-cisco sfp?
Yes that will work, provided the optical modes are the same. M.
baselzind
sorry, what do you mean by M?
   - I mean  that you can, of course not mix singe mode versus multi-mode fiber.
 M.
