A serious problem for LMS 4.1
CSCO11616177
Hi guys,
        1.When I want to add a CPU alarm, prompted me:
Message
Failed to Create Alarm !
Cause
1)Could be invalid value for some of the entries
2)Could be due to lack of access to the host,invalid SNMP credentials or a busy device.
Action
1)Verify the values entered for all the entries.
2)Verify that the Alarm Variable resolves to one of the following ASN.1 primitive types
. INTEGER
. Integer32
. Counter32
. Counter64
. Gauge
. TimeTicks
3) Verify access, SNMP credentials or increasing timeout value through
Message
Cause
Action
. INTEGER
. Integer32
. Counter32
. Counter64
. Gauge
. TimeTicks
        2.After I  enable HTTPS ,login LMS finished entering username password I need to manually modify the port number. Link 111.jpg
I need change 1741 to  443, otherwise, can not access
3.Topology Services. It prompts me to download Java again and again
Every time I have installed have prompted this
But have not been able to properly display
Help me, please
Thanks a lot
AFROJ AHMAD
Hi ,
For the First issue :: try to delete and re-add the device ,make sure you have the correct SNMP credentilas
Second Issue:
Delete the existing shortcut and create new one by following the below steps.
1.       Right click on the
