AAA on C9500
baileyTh
Beginner
Beginner
I have AAA up and running on several switches ( all cisco) but my C9500 errors out with (No authoritative response from any server).  My config for AAA on the C9500 mirrors all the other switches.  All the switches pass thru the C9500 and the AAA server is attached to  the C9500.  I can't send my config but what direction might I look to figure this out?
balaji.bandi
VIP Community Legend VIP Community Legend
Can you post what code running on Cat 9500, also AAA config.
This is most probably config, issue, some time Cat 9500 use Manangement VRF, if you using source IP or interface in the config.
#show tacacs
BB
MHM Cisco World
VIP Mentor VIP Mentor
VIP Mentor
I will start with
aaa test
and if you can share result here
Georg Pauwen
VIP Master VIP Master
VIP Master
can you ping the TACACS or RADIUS server from the 9500 ?
Recognize Your Peers
