About bus error
benche
If the router has the bus error message and it indicates the address, how can I identify which part of hardware within the router has problem (which memory slot or module)?
For example:
System was restarted by bus error at PC 0x400B9A58, address 0xB0D0AFD at 12:38:40 MO Fri Mar 31 2006
It is a 2811 router.
balajitvk
Level 4
Level 4
Hi Benche,
The system encounters a bus error when the processor tries to access a memory location that either does not exist (a software error) or does not respond properly (a hardware problem).
There is a detailed procedure to troubleshoot this kind bus errors. There is a link describing this,
http://www.cisco.com/en/US/partner/products/sw/iosswrel/ps1831/products_tech_note09186a00800cdd51.shtml
Rate if it helps,
Rgs
balajitvk
Level 4
Level 4
Hi Benche,
Rate if it helps,
Rgs
Thank you!!
