Highlighted
Beginner
Access-class stop working after upgrade to 15.7
I have a C2911 router, after upgrade to 15.7, the "access-class xxxx in vrf-also" command seems to be blocking all the access, I have to remove this line so that the telnet/ssh can be working again.
I am seeing the same issue on CSR I have one is running version 16.9.4, same thing, I have to remove the "access-class" under the "vty 0 4".
are there anything changed about this "access-class" command?
0 REPLIES 0
Content for Community-Ad
