ACE Module and RME 4.3.1
We use RME Version 4.3.1. ACE-Modul has SysObject-ID .1.3.6.1.4.1.9.1.1291.
Is this Modul supported?
Hansruedi
shmcguir
Hi Hansruedi,
This device currently isn't supported in any version of LMS.
If you need support for this device I would go ahead and contact your Cisco Account Manager and ask them to open a Product Enhancement Request to have support for this device added to LMS.
You can check at the following for the list of currently supported devices in RME 4.3.1:
http://www.cisco.com/cisco/software/release.html?mdfid=282635175&flowid=5145&softwareid=280775121&release=4.3.1&rellifecycle=&relind=AVAILABLE&reltype=latest
http://www.cisco.com/en/US/partner/docs/net_mgmt/ciscoworks_lan_management_solution/3.2/device_support/table/lms32sdt.html
Best regards,
Shane
shmcguir
Hi Hansruedi,
Best regards,
Shane
Hi Shane,
Thank you very much for your help.
Hansruedi
