ACS 3.3 Distribution Proxy
mironduplessis
Beginner
Beginner
I have an ACS 3.3 Server for authenticating local users username@localcompany.com .I am trying to configure the server to proxy requests for remote users to an external Radius Server. username@remote.com
I created a distribution table entry that has a character string off:
@remote.com
and selected the remote radius server.
The default table entry points to the internal server.
This however does not work local accounts get authenticated and remote accounts are still checked on the local server and fail.
If I change the default table entry to use the remote server. The requests for both local and remote get sent to the remote however the "@x.com" gets stripped off even though its set not to strip off.
Does anyone have any advice with regards to this problem.
Thanks is advance
Miron
