06-02-2009 06:01 AM
LMS 2.6 / RME 4.0.6
Hi, I have an ASA 5550. I have installed the ASA 2.1 package and have verified that the OID is supported. When I add the device to the DCA the credentials check fails and I get a device not supported message.
Can anyone advise me on how to troubleshoot this?
06-02-2009 07:58 AM
Do you have the SNMP RO configured and it matches what you enter in LMS? Do you also have the snmp-server host command added to the ASA which points to the IP address of LMS?
06-03-2009 01:07 AM
Hi davistan,
Yes, the snmp settings are on the ASA and in LMS. I can perform an snmp-walk of the ASA from LMS.
Piaras
