After updating WS-C2960S-48TS-L no longer able to be added to CNA 6.3
SirLoki
I had CNA working with the same Switch along with the rest of my community which consists of mostly 2960-X's now. Wanted to bring the 2960-S up to a more recent tar and selected the one that was recommended stable on the Cisco Download page 15.0.2.SE12. All the release notes for CNA say it is supported.
I launched the update from CNA and after it completed it would not load back on the map - I checked the IP address and was able to login to the web management and shows the update was successful and that it is running on the new version but when i try to add it back to my community in CNA it keeps saying that WS-C2960S-48TS-L is an Unsupported Device type
I want to restart the switch and maybe try reinstalling the firmware but cannot do to much during the day. If anyone has any suggestions it would be much appreciated!
llneely
Did you find a solution for this.
Hello
I personally dont use CNA, however after a quick search on CSC i found this post, hope it may be of help?
https://community.cisco.com/t5/network-management/ws-c2960s-48ts-l-showing-as-unsupported-device-in-cna-5-5/td-p/1439693
Kind Regards
Paul
I have tried many versions including 6.3.3 which is the latest and has support for the 2960s with same results.
This article talks about 5.5 not supporting.
