Highlighted
AIRCAP 3702I-A-K9
Hello. My Apple time capsule just broke down and i got this Cisco Product at Home just laying around the house.
Is it suitable for homeusage or even possibile to use it as a router instead of a more simpler router of other brand?
If yes, is there some step by step guidance to take me from start to finish?
Greatful for your support. Kind regards
/Magnus
1 ACCEPTED SOLUTION
VIP Advisor
Re: AIRCAP 3702I-A-K9
Hi there,
What you have is an access-point, not a router. Thankfully an autonomous image is available for it, meaning it can be configured without a Wireless LAN Controller so is not completely useless for home deployment.
https://software.cisco.com/download/home/286287624/type/284180979/release/15.3.3-JJ1
You will still need a router though.
cheers,
Seb.
1 REPLY 1
VIP Advisor
Hi there,
cheers,
Seb.
Content for Community-Ad
July's Community Spotlight Awards
