We are getting 2 message from ACS 5. 3 and incremental backup changing state to OFF in the web portal.
1. Incremental backup is not configured. Configuring incremental backup is necessary to make the database purge successful. This will help to avoid disk space issues. View database Size is 0.51GB and size it occupies on the harddisk is 0.49GB.
2. Alarm caused by ACS - Process Status threshold
Please find the attachment and help us.
Occurred At:
Fri Sep 05 09:40:00 IST 2014
Cause:
Details:
Following processes were not running between Fri Sep 05 09:38:00 IST 2014 and Fri Sep 05 09:40:00 IST 2014 for the ACS Instance(s): ACS InstanceTimeProcesses
Name:
Description:
ACS database, management and runtime process monitor
Monitored Processes:
ACS Management ACS Runtime Monitoring and Reporting Collector Monitoring and Reporting AlarmsManager Monitoring and Reporting JobManager Monitoring and Reporting LogProcessor
