Alerts from Cisco LMS
durghamj7
Dears I have some concerns about SNMP and Cisco LMS :
Our network device sent a LINK DOWN trap to CISCO LMS followed by LINK UP trap . I can see these messages from the device logs . My questions is :
1-If the device is configured correctly to send snmp traps .And the syslog is showing both messages (LINK DOWN , LINK UP) then we can say the device is sending the snmp traps ?
2-Why the LINK UP trap is missing in Cisco LMS .. What should we check to make sure LMS is sending and receiving these alert in proper way  ???
Thanks in advance .
correct , if the SNMP TRAP is enabled then ideally snmp trap will be sent.
Thanks-
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
AFROJ AHMAD
Hi ,
Syslogs are different from SNMP traps , If you are seeing syslogs for linkup and linkdown ,it does not mean that device is sending the SNMP traps as well.
You can verify the snmp trap by packet capture
Thanks-
Afroz
Thanks Mr.AFROJ for the reply
We all know that the snmp traps is different than syslog but the real question is if the device recognize a LINK DOWN , LINK UP for any interface and it record it in syslog .
Then the device should send the snmp trap -if configured- at the same time shown in the syslog , right ?
Thanks .
Thanks-
