Another Baseline Question - interfaces
simon.bell
I'm trying to create a template that checks all 48 fa ports to ensure they have port security, are in access mode, portfast etc. I don't think i can do this with a basic template and can't figure out how in a basic template. Anyone done this before? If so, perhaps you could even attach the xml so i can see how it works.
TIA
Here it is inline:
switchport mode access spanning-tree portfast switchport port-securityinterface [#FastEthernet.*#]
8 Replies 8
Joe Clarke
Exactly what version of RME are you using? This is very easy to do using an advanced template assuming ALL 48 ports need to be checked for the same commands.
We're running RME 4.1.1 and yes all ports would be checked for the same settings.
Thanks!
This sample template should get you started.
Reposting with a .txt extension. Rename to .xml.
Reposting compressed.
Nope I still can't download it. can you just email me the attachment as a txt file?
Here it is inline:
thx, looks like it was a problem with our sidewinders after all.
