Ansible Nexus ACL push abort config session on Failure
TheHubGuy
Hey team,
We are trying to push ACL via nxos_config and our playbook has steps for something like this:
config session
no ip access-list test_ingress
permit blah blah
commit
The issue we are seeing with this playbook is, whenever there is a failure for any of the ACL lines, the session gets committed instead of aborted.
test_ingress ; permit tcp 1.1.1.1/32 2.2.2.2/32 eq 443 (FAILURE) (from the accounting logs)
... and the session is committed.
Is there a way to abort the session if we see any FAILURE? The failure can be due to tacacs accounting.
the line would be:
any_errors_fatal: true
Can you post your entire playbook so we can test ? What exactly do you mean by:
-->  whenever there is a failure for any of the ACL lines, the session gets committed instead of aborted.
What does a 'failure' mean in this context ?
Hi Georg,
When we push the ACL via like this:
config session
permit #ACL1
permit #ACL2
permit #ACL10005
permit #ACL 20000
commit
if any of that ACL line fails to get pushed to the box, the session is committed right away. Let's say #ACL10005 gets failed to push, the session is committed without pushing anything after #ACL10005. We would like to abort the config session in this case rather than commit it.
--- Playbook -----
main.yaml
- name: precheck commands
  cisco.nxos.nxos_command:
    commands:
      - "{{ item }}"
  loop: "{{ precheck }}"
  ignore_errors: yes
  register: precheck_command_outputs
- name: NXOS FACTS | GATHER FACTS
  cisco.nxos.nxos_facts:
    gather_subset:
      - config
      - "!default"
- name: ACL push - add
  cisco.nxos.nxos_config:
    save_when: modified
    lines: "{{ lookup('template', 'nxos_acl_add.j2') }}"
    replace: block
    match: none
  retries: 3
  register: aclpush
  until: aclpush.failed|bool == false
  when: " acl_change.acl_parent_line not in ansible_net_config"
- name: postcheck commands
    commands:
      - "{{ item }}"
  loop: "{{ postcheck }}"
ignore_errors: yes
nxos_acl_add.j2
config session ansible-acl-push
{{ acl_change.acl_parent_line }}
{% for line in acl_change.acl_content %}
  {{ line }}
{% endfor %}
commit
what if you add the line marked in bold (as previously suggested) ?
--> any_errors_fatal: true
commands:
- "{{ item }}"
ignore_errors: yes
gather_subset:
- config
- "!default"
save_when: modified
replace: block
match: none
retries: 3
register: aclpush
commands:
- "{{ item }}"
ignore_errors: yes
