Cisco Community Designated VIP Class of 2020
151
Anyconnect + ACS single client simultaneous connections limitation
Hi.
I need to limit single anyconnect user (created in ACS) by using ACL on ASA and framed ip in ACS.
Problem is when client disconnects and reconnects he get new ip address and ACL doesn't apply for this connection any more.
First connection:
Username : artemtest
Assigned IP : 10.3.3.21 (this is framed IP)
Second connection:
Assigned IP : 10.3.3.23 (this is not framed IP)
Is there a way to limit simultaneous connections? Or maybe there are some other ways to limit access to network resources for that single anyconnect user?
Thank you.
1 ACCEPTED SOLUTION
VIP Rising star
Re: Anyconnect + ACS single client simultaneous connections limitation
you can configure the session limit in ACS, but it has its limitations.
from user guide
ACS 5.8 allows you to configure a maximum session limit for any user in the group; for example, each user belonging to a specific Identity Group may open not more than the session limit, no matter how many sessions other users from the same group have opened. There is no option to set up a session limit for a particular user
2 REPLIES 2
VIP Rising star
from user guide
Highlighted
Thank you pieterh!
Content for Community-Ad
July's Community Spotlight Awards
