01-03-2022 11:04 PM
Nothing opens after connecting tho Cisco AnyConnect
@cisco @AnyConnect
01-03-2022 11:29 PM
We do not have enough information to understand your problem or to give you good advice. Here are some questions to help get started in trying to understand the issue.
- has this ever worked? Or is this a new install of AnyConnect?
- is this done on real hardware or is this in some emulator?
- is this in a live environment, in a lab environment, in a student project?
- is AnyConnect installed on an ASA or on a router?
- what version of AnyConnect is installed?
- when you have attempted to use AnyConnect can you check the logs on the device where AnyConnect is installed and tell us if there are any log messages about AnyConnect?
- can the machine where you are trying to use AnyConnect ping, traceroute/tracert to the machine where AnyConnect is installed?
- have you tried AnyConnect from another device?
01-04-2022 12:36 AM
01-04-2022 09:13 AM
as Richard already asked, what is the AnyConnect client terminating on ? An ASA or a router ? The link you posted just leads to the download page for the AnyConnect client.
You need to provide more information in order for us to be able to help you.
