206
Beginner
Anyone Using A Product That Shows Device Availablity
My managemetn wants to generate report showing avialability of circuits, and major network componets. The report generation has to be flexible (ie monthly, daily, weekly). Is anyone using such a product and can recommend it? They're mad because the rep said Cisco Works would do.
Thanks in advance,
Dave Holder
2 ACCEPTED SOLUTIONS
Contributor
Re: Anyone Using A Product That Shows Device Availablity
Depends on your definitions
You can get IPM to check the link between two devices, but you will have to create a collector for each.
You can create another collector for each "major network componet" to ping the ciscoworks server
These 2 actions will give reports that can be seem as an availability report.
Cheers,
Michel
Beginner
Try Solarwinds Orion....very nice product @ a good price.
Beginner
CiscoWorks will give you some basic up/down reporting - however it is limited.
I would suggest trying an open source package. There are some out there that is very sophisticated and will give you the 'pretty' reports your management needs.
Give these a try:
NMIS - http://www.sins.com.au/nmis/
NeDi - http://nedi.sourceforge.net/
Nagios - http://www.nagios.org/
Scott
Rising star
Hey Dave,
your name sounds very familiar. I don't owe you money do I? If I don't you can drop me an e-mail off-line at tdennis@DataSourcePro.com. Let's confirm that what you have won't do the job before you buy another product.
Travis
Contributor
Cheers,
Michel
Beginner
Highlighted
Beginner
I'd recommend OpenNMS:
http://www.opennms.org
It's a little more advanced that Nagios and also gives you some of the same stuff as MRTG and MRTG derivatives.
Beginner
Check www.statseeker.com
Gives all kind of reports from link utilisation down to port usage. Also has great managment reporting for SLA's. A bit pricy but good on large networks for full blanket monitoring.
Beginner
For the Network Management u can USe the Net Disco Network Managemetn Tool an Open Source Product.
http://netdisco.org/
Ask the Expert- MPLS troubleshooting
