AP 1142 ssid dropping activity
tapedeckghost
I'm running a wpa2-secured guest ssid on a particular vlan that allows traffic to the web but restricts any access to internal network resources. It had been working fine for a couple of weeks, until the network started intermittenly dropping - at first I tried swapping channels and rebooting, but there has been no progress. I keep a running log at all times as long as the network is still active, but once it drops, the only message I'm getting is '
Line protocol on Interface Dot11Radio0, changed state to down'
My understanding would be that this is the same message logged when a user manually turns off the radio from a terminal window, is this correct? Or am I missing some basic troubleshooting steps?
dot11radio0 line
Leo Laohoo
Can you please post the complete output for the command "sh version" please?
Cisco IOS Software, C1140 Software (C1140-K9W7-M), Version 12.4(21a)JA1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Wed 16-Sep-09 18:09 by prod_rel_team
ROM: Bootstrap program is C1140 boot loader
BOOTLDR: C1140 Boot Loader (C1140-BOOT-M) Version 12.4(18a)JA3, RELEASE SOFTWARE (fc1)
xxxxx uptime is 16 hours, 22 minutes
System returned to ROM by reload
System image file is "flash:/c1140-k9w7-mx.124-21a.JA1/c1140-k9w7-mx.124-21a.JA1"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-AP1142N-A-K9     (PowerPC405ex) processor (revision B0) with 98294K/32768K bytes of memory.
Processor board ID FTX1449E08X
PowerPC405ex CPU at 586Mhz, revision number 0x147E
Last reset from reload
1 Gigabit Ethernet interface
2 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: xx:xx:xx:xx:xx:xx
Part Number                          : 73-11451-08
PCA Assembly Number                  : 800-30554-06
PCA Revision Number                  : A0
PCB Serial Number                    : FOC14471CML
Top Assembly Part Number             : 800-31273-04
Top Assembly Serial Number           : FTX1449E08X
Top Revision Number                  : A0
Product/Model Number                 : AIR-AP1142N-A-K9
Configuration register is 0xF
There you go
Thanks for the output.
Can you download the Bootstrap of the 1140 and upgrade to 12.4(23c)JA1?
To install, use the command "copy tftp:///Bootstrap filename bs:"
