cancelar
Mostrar resultados para
Pesquisar em vez de
Queria dizer:
Apresentações
Útil
Respostas
ap 9115 can't change primary and secondary controller via cli
noemifabbri
Hi everyone,
We were try to change via cli the primary and secondary controller configured on a 9115 ap.
While we were saving the configuration no error was shown, so we believed they were changed as we wanted. The configuration were shown still as the old one, so we tried to reload the ap but nothing changed.
We tried with different ap, some connected to a wlc 9800 (with version 17.9.4a) and some connected to a wlc (version 17.3.7).
Any suggestion?
Thanks a lot,
Noemi
5 RESPOSTAS 5
balaji.bandi
what command you used to change on WLC ?
i have tried all the time using WLC 9800 GUI that works as expected.
BB
From the WLC 9800 GUI everything worked as expected, but our problem is with the cli.
Right now our config is : primary-base x.x.x.7 and secondary base x.x.x.16
What we wanted to do is : primary-base x.x.x.16 and secondary base x.x.x.7 , but via cli if we configure the right commands (primary and secondary) they aren't changed as they should.
If it connect to WLC the config is push from wlc to AP which override the AP previous config.
So you need to config AP and make sure that WLC that AP connect to also have same config.
MHM
One/two months ago we launched a job on Orion that works via cli on every single ap, switching the primary to the secondary with no problems (with the commands primary and secondary base). We moved this way like 100 ap's, the same ap's that we're trying now to move back, with the same job and/or manually, but it is not working.
i just tried as below it works - from WLC
# ap name <AP_name> controller primary <WLC_name> <WLC_IP>
BB
