Hi ,
Try the below steps and see how it works :
On the command Prompt run this commad to check the Dependency of the Apache :
C:\PROGRA~2\CSCOpx\MDC\Apache\bin>pdreg -l Apache
Process = Apache
Path = C:\PROGRA~2\CSCOpx\MDC\Apache\bin\Apache.exe
Flags = -d C:\PROGRA~2\CSCOpx\MDC\Apache -D SSL
Startup = y
Dependencies = Tomcat
Now Unregister the Apache with below commad :
pdreg -u Apache
To Registered the Apache:
Note :You need to check the Apache.exe location ,so anyone of the below will work for you :
C:\PROGRA~2\CSCOpx\MDC\Apache\bin>pdreg -r Apache -e "C:\PROGRA~2\CSCOpx\MDC\Apache\bin\Apache.exe" -f "-d C:\PROGRA~2\CSCOpx\MDC\Apache -D SSL" -d Tomcat
(used your NMSROOT Location )
C:\PROGRA~2\CSCOpx\MDC\Apache\bin>pdreg -r Apache -e "C:\PROGRA~2\CSCOpx\MDC\Apache\Apache.exe" -f "-d C:\PROGRA~2\CSCOpx\MDC\Apache -D SSL" -d Tomcat
Now re-check the Apache Registration :
Process = Apache
Startup = y
Once above is done try to Restart the Apache and check how it works !!
Thanks--
Afroj
Thanks-
Afroz
[Do rate the useful post]
****Ratings Encourages Contributors ****
