APIC-EM EasyQoS compatibility with 1941 ISR router
VRizk
I'm wondering if the APIC-EM easyqos feature is compatible with a 1941 ISR router ? I was trying with an 1841 router to which I found out it isn't supported. Before I switch routers I wanted to double check as I'm not seeing anything saying this router isn't supported?
marce1000
 - Can't confirm it is supported ; check links from (no references to your device were found) :
https://www.cisco.com/c/en/us/support/cloud-systems-management/one-enterprise-network-controller/products-device-support-tables-list.html
M.
