APIPA IP address conflict
vytenis
I have number of CBS350 series switches. My NMS, which is not Cisco brand, generates errors:
"Interface User Defined Port 1 of device at 172.18.136.71 and interface User Defined Port 1 of device at 172.18.136.84 have a conflicting IP address 169.254.0.1.
How I suppose to deal with it?
Thank you
  - Similar to this discussion : https://community.arubanetworks.com/discussion/e0706p06-loopback-conflict
     it looks like an issue within NMS only; there is  also a workaround provided, try it out.
  M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
8 Replies 8
Mark Elsen
                        - FYI : https://www.webopedia.com/definitions/apipa/
             Make sure a unique address can be provisioned for different devices through a DHCP server,
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Sorry, forgot to say. There is no DHCP server on the LAN.
  - Then I suspect the IP settings on some of the devices is wrong or  there is a conflict.
  M.
       Beauty and terror
      Just keep going
       No feeling is final
Switch management IP addresses are correct and different an it is visible in the error message. Obviously, APIPA address is same and conflicting. The big question is how do I disable it or change?
  - What is the switch model ?
  M.
       Beauty and terror
      Just keep going
       No feeling is final
(172.18.136.72) CBS350-8T-E-2G 172.18.136.72 Cisco Switches
(172.18.136.86) CBS350-16T-2G 172.18.136.86 Cisco Switches
(172.18.136.87) CBS350-16P-2G 172.18.136.87 Cisco Switches
(172.18.136.83) CBS350-8T-E-2G 172.18.136.83 Cisco Switches
(172.18.136.71) CBS350-8P-E-2G 172.18.136.71 Cisco Switches
(172.18.136.82) CBS350-8T-E-2G 172.18.136.82 Cisco Switches
(172.18.136.81) CBS350-8FP-E-2G 172.18.136.81 Cisco Switches
I will clarify that *all* these switches have those warnings.
Now I found that each switch error has 172.18.136.71 as a conflicting device. Checking now 172.18.136.71 config and can't find anything which may cause that behavior. I will upload config if asked.
  M.
       Beauty and terror
      Just keep going
       No feeling is final
Thank you very much!
Will read carefully and apply suggestions.
