Participant
App for Device Management
Any suggestions for device management software. I'm referring software that performs the same function as mRemote visionapp Remote Desktop?
I really like it, but it is getting a bit old and not supported.
I am looking for something that will aliow me to set up SSH, RDP, HTTPS sessions with automatic login credentials. Also, able to integrate apps like Visio... for instance, open a visio doc that is located on the network/
Any experience with others?
Thank you
Content for Community-Ad
July's Community Spotlight Awards
