Hi everyone,
I have an applet configured to monitor CPU going above 50%, this was working previously but it suddenly stopped appending on the file. The file system has space on it. I also did a show "show clock - append sup-bootdisk:TEST-CLOCK.tx" and it worked. The event manager registers the event but it doesn't write. Here is my config:
event manager scheduler script thread class default number 1
event manager applet high_CPU
event snmp oid "1.3.6.1.4.1.9.9.109.1.1.1.1.10" get-type next entry-op ge entry-val "50" exit-op le exit-val "5" poll-interval 5
action 0.0 syslog msg "High CPU DETECTED. Please wait logging Information to sup-bootdisk:high_cpu_BOTMAN01.txt"
action 0.1 cli command "enable"
action 0.2 cli command "term exec prompt timestamp"
action 0.3 cli command "term len 0"
action 1.1 cli command "show clock | append sup-bootdisk:high_cpu_BOTMAN01.txt"
action 1.2 cli command "show processes cpu sorted | append sup-bootdisk:high_cpu_BOTMAN01.txt"
action 1.3 cli command "show processes cpu detailed | append sup-bootdisk:high_cpu_BOTMAN01.txt"
action 1.4 cli command "show ip route summary | append sup-bootdisk:high_cpu_BOTMAN01.txt"
action 1.5 cli command "show ip route | include 00:00: | append sup-bootdisk:high_cpu_BOTMAN01.txt"
action 2.0 cli command "end"
show event manager history events
No. Time of Event Event Type Name
1 Wed Oct25 01:08:51 2017 snmp applet: high_CPU
2 Thu Oct26 13:42:52 2017 snmp applet: high_CPU
3 Sat Oct28 01:06:09 2017 snmp applet: high_CPU
4 Mon Oct30 01:08:02 2017 snmp applet: high_CPU
5 Mon Oct30 09:18:26 2017 snmp applet: high_CPU
6 Mon Oct30 09:29:46 2017 snmp applet: high_CPU
7 Mon Oct30 09:31:26 2017 snmp applet: high_CPU
8 Mon Oct30 09:32:21 2017 snmp applet: high_CPU
9 Mon Oct30 09:32:31 2017 snmp applet: high_CPU
10 Mon Oct30 09:41:42 2017 snmp applet: high_CPU
The device is a 6504-E running 12.2(33)SXH6
Solved! Go to Solution.
If you have AAA command authorization configured, it could be blocking the commands. Enable "debug event manager action cli" and see what output you get.
Hi Hiram
Could you please paste the output of "show file system". Just want to make sure if you have sup-bootdisk: or sup-bootflash:.
Also, could you please perform the below test:
copy run sup-bootdisk:startup-config.txt
Hi Vinit,
File Systems:
Size(b) Free(b) Type Flags Prefixes
- - opaque rw system:
- - opaque rw tmpsys:
- - opaque ro flexwan-fpd:
* 511705088 511705088 disk rw disk0:#
- - disk rw disk1:
512024576 157442048 disk rw sup-bootdisk: sup-bootflash:#
73138346 0 opaque ro sup-microcode:
0 199835804 opaque wo sup-image:
129004 128208 nvram rw const_nvram:
1964024 1939175 nvram rw nvram:
- - opaque rw null:
- - opaque ro tar:
- - network rw tftp:
- - opaque wo syslog:
65536000 65196656 flash rw bootflash:
- - network rw rcp:
- - network rw ftp:
- - network rw http:
- - network rw scp:
- - network rw https:
- - opaque ro cns:
32055296 32055296 flash rw ssc4-disk0:
15990784 15990784 flash rw dfc#2-bootflash:
#copy running-config sup-bootdisk:startup-config.txt
Destination filename [startup-config.txt]?
19846 bytes copied in 2.888 secs (6872 bytes/sec)
Hi Joe,
Thanks for your help
I activated the debug, I see Command Authorization Failed. I entered "event manager session cli username <username>", let's hope that fixes it.
