ā01-31-2018 04:13 AM - edited ā03-01-2019 06:22 PM
Hello!
I have an ASA5506X with FirePower, version 6.2.2.1 (Build 73). I can't change the Default System Policy. I have got the Invalid object type error (see attached screenshot).
Does anybody have an idea what causes of this error ?
ā01-31-2018 05:19 AM
- Is this interface browser based ? If so could you try another browser ?
M.
ā01-31-2018 05:32 AM
Thanks for your input marce1000! I manage this ASA with ASDM, so it's Java based administration. By the way, I tried another OS and still have no luck. I believe this error is not tied to the client management software. It's must be somewhat under the hood. Maybe in the MySQL database or elsewhere. If this will help, ASA is 9.8.2.15 and ASDM is 9.8.2. Unfortunately, opening a TAC case is not an option this time.
ā01-31-2018 05:39 AM
- I tend to believe it could be ASDM related, but opinions may vary indeed; perhaps try another ASDM version (if time permits).
M.
ā02-01-2018 06:44 AM
I noticed I have the same problem this morning. I noticed that my FirePower scheduled tasks were not running when I expected them to. I then found that the time appears to be UTC instead of EST. I clicked on System Policy to attempt to check the time synchronization settings and got the error "Invalid object type".
ā02-01-2018 09:23 PM
I'm sorry, but I did not find how to move topic to another corner, or simply delete. So I decided to create another one, in the Security management. I do apologize again.
