Beginner
ASA 5516 SNMP temperature monitoring
is it possible to get any temperature information via SNMP for an ASA 5516?
If yes - which OID and MIB do I need for this?
1 ACCEPTED SOLUTION
Participant
Re: ASA 5516 SNMP temperature monitoring
We use 1.3.6.1.2.1.99.1.1.1.4 to obtain the temperature values for our 5525s it might be the same for the 5516s
1.3.6.1.2.1.99.1.1.1 is the table if you need any more info around the values.
Hopefully this is helpful.
5 REPLIES 5
Participant
Beginner
Thank you. This is working. I found one item that seems to be the fan. And then three temperatures (I don't know which temperatures exactly these are but they have all a similar value at the moment).
Highlighted
Participant
I ran into a similar issues creating custom sensors in our monitoring solution. I ran show environment temperature on the ASA and cross referenced with the values when I did an SNMP walk on the OID.
The 4 temperature values should be for the processor, chassis back, chassis front and chassis back left according to sho env temp. The processor value will be the highest.
VIP Advisor
snmpwalk with below oid
ciscoEnvMonTemperatureStatusTable 1.3.6.1.4.1.9.9.13.1.3
entitySensorMIBObjects 1.3.6.1.4.1.9.9.91.1
BB
*** Rate All Helpful Responses ***
Beginner
This is not working in my case.
CISCO-ENVMON-MIB::ciscoEnvMonTemperatureStatusTable = No Such Object available on this agent at this OID
Content for Community-Ad
July's Community Spotlight Awards
