09-21-2020 11:19 AM
We are running a cluster of Cisco ASA 5545-X 9.9(2) at our edge for web traffic. We have a requirement to run Exchange Online classic hybrid through it. That architecture requires ingress TCP ports 443/25 from a dynamic list of Office 365 endpoints. Other proxy/firewall kit we have has capability to subscribe to the Office 365 managed endpoints feed and auto-updated rules. ASA does not appear to have this capability.
Is there any other automation capability in ASA we could leverage for this? I see mention of a REST API based on a JAVA app running on the ASA itself but I have no experience of it in relation to stability, security etc. If it is was stable and had a reasonably granular security model around it potentially I could look to use it to upload the updated rules et each month as needed.
Solved! Go to Solution.
09-24-2020 02:53 AM
that is the example, you can do based on your ACL modification, look at the REST API and Limitation if any.
09-21-2020 12:15 PM - edited 09-21-2020 12:15 PM
I seen that working with FMC and API, ASA not tied, since we moved to FTD.
You can use REST API based here some reference :
https://halis.eu/2018/07/22/script-to-import-office-365-ip-list-to-cisco-asa-improved-via-rest-api/
09-24-2020 01:29 AM
So basically this script is creating an entire ACL set and uploading via the ASA REST API i.e. replacing the existing rule set in its entirety?
09-24-2020 02:53 AM
