03-06-2012 06:53 AM
Hi all,
Can anyone tell me if it is possible to add an ASA and ACS to LMS 4.0 device management?
Does LMS also backup the config of those devices?
Best Regards,
Joris
03-06-2012 02:46 PM
ASA, yes. ACS (assuming not a typo for ACE, but Cisco Secure ACS), no. The full supported device list is found at:
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/4.1/device_support/table/lms41sdt.html
