09-23-2015 06:29 AM
Hi everybody!
we experienced a port failure om a brand new 5525X. The port looked to be up/up but no layer 2 traffic was transmitted. The interface was configured as outside, and when we moved outside to gig0/3 everything worked. We reloaded the ASA box twice, no luck.
any ideas how to debug a failure like this?
regards, Michael
Solved! Go to Solution.
09-24-2015 10:25 AM
There is no a specif command to check if the interface might be faulty, you can check the physical indicators such as the LED status ( green , amber , red , no light and the cabling.)
This document might help you to troubleshoot if there is any error on the interface
https://supportforums.cisco.com/document/47506/asa-oversubscription-interface-errors-troubleshooting
Otherwise the device needs to be replaced.
-Randy-
09-23-2015 11:54 AM
Hi Michael,
You can clear the interface counters and attempt to pass traffic and check if the counters increment.
clear interface gig0/x
Show interface gig0/x
If the conters do not increment might indicate a Hardware issue, if you have a valid Cisco contract feel free to open a ticket with Cisco TAC to replace the device.
Hope it helps
- Randy -
09-24-2015 08:10 AM
Hi Randy,
Thanks for the reply.
Is it safe to assume that if the interface counter does not increase, and the interface is UP/UP, it is a hardware failure? Isn’t there any command that would validate that the interface might be broken in some way?
09-24-2015 10:25 AM
-Randy-
