06-01-2020 04:35 AM
Hi everybody.
As this is my first post, I do hope that i'm in the right place :)
I have a problem with my ASDM installation, that I've never seen before.
When I first startup the ASDM everything looks fine, but as soon as I move my cursor around, the problems start.
It's almost impossible to do any kind of work on my ASA, as you can see in the attached picture.
It's a freshly installed ASDM, and fully updated JAVA version.
ASDM Version: 7.12(2)
OS: Windows10 1909
I hope that you guys/gals might have some suggestions :)
Kind Regards
Kasper J.
06-01-2020 09:38 AM
Ref : https://www.cisco.com/c/en/us/td/docs/security/asdm/7_12/release/notes/rn712.html#id_25472
I would commit to the ASDM Java Requirements as mentioned in that paragraph and commit to that version
M.
06-09-2020 09:43 AM - edited 06-09-2020 09:45 AM
I apologize for the late reply, but there has been some sickness in the family.
I've tried downgrading to Java version 8.0 (As per the article you linked too), but now ASDM won't even start.
Nothing weird happens, no errors, it just doesn't start.
**EDIT**
I've tried both the 32bit and the 64bit versions.
06-09-2020 10:28 AM
- Reboot your system, if the problem is persistent then afterwards, check the Windows Eventlog (application and system). Check if anything is being reported which can clarify this issue.
M.
06-09-2020 11:44 AM
Already tried that, same result.
I have an old laptop running the same ASDM version, and Java Version 8 Update 161 which works without any problems. I've tried to install the exact same version of Java on my Desktop, but I still have the same problem.
I'll try and check the Windows logs, and report back :)
06-09-2020 12:37 PM
Nothing usefull in the logs, unfortunately.
06-09-2020 01:23 PM
A few others have had the same issue, which was solved in another thread, by overriding the DPI settings.
https://community.cisco.com/t5/network-security/asdm-screen-issues/m-p/3192060
I've tried the same solution, but I still have the problem.
I'm using a 27" monitor at 2560*1440.
