01-21-2014 11:13 AM
I had my ASA working from work and the other day I started getting an error:
UNABLE TO LAUNCH DEVICE MANAGER FROM (MY STATIC IP @ HOME)
It used to work fine and I am able to load it on my local network. Someone said it might be my Java version. So I downloaded Java 6 and installed that, no change. Anyone have any ideas on what it might be?
Application Logging Started at Tue Jan 21 12:04:58 MST 2014
Local Launcher Version = 1.5.69
Local Launcher Version Display = 1.5(69)
OK button clicked
java.lang.NullPointerException
at com.sun.deploy.security.DeployManifestChecker.printWarningsIfRequired(Unknown Source)
at com.sun.deploy.security.TrustDeciderDialog.doShowDialog(Unknown Source)
at com.sun.deploy.security.TrustDeciderDialog.showDialog(Unknown Source)
at com.sun.deploy.security.X509Extended7DeployTrustManager.checkServerTrusted(Unknown Source)
at sun.security.ssl.ClientHandshaker.serverCertificate(Unknown Source)
at sun.security.ssl.ClientHandshaker.processMessage(Unknown Source)
at sun.security.ssl.Handshaker.processLoop(Unknown Source)
at sun.security.ssl.Handshaker.process_record(Unknown Source)
at sun.security.ssl.SSLSocketImpl.readRecord(Unknown Source)
at sun.security.ssl.SSLSocketImpl.performInitialHandshake(Unknown Source)
at sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source)
at sun.net.www.protocol.https.HttpsClient.afterConnect(Unknown Source)
at sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.connect(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(Unknown Source)
at sun.net.www.protocol.https.HttpsURLConnectionImpl.getInputStream(Unknown Source)
at com.cisco.launcher.s.new(Unknown Source)
at com.cisco.launcher.s.actionPerformed(Unknown Source)
at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at javax.swing.AbstractButton.doClick(Unknown Source)
at javax.swing.plaf.basic.BasicRootPaneUI$Actions.actionPerformed(Unknown Source)
at javax.swing.SwingUtilities.notifyAction(Unknown Source)
at javax.swing.JComponent.processKeyBinding(Unknown Source)
at javax.swing.KeyboardManager.fireBinding(Unknown Source)
at javax.swing.KeyboardManager.fireKeyboardAction(Unknown Source)
at javax.swing.JComponent.processKeyBindingsForAllComponents(Unknown Source)
at javax.swing.JComponent.processKeyBindings(Unknown Source)
at javax.swing.JComponent.processKeyEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.KeyboardFocusManager.redispatchEvent(Unknown Source)
at java.awt.DefaultKeyboardFocusManager.dispatchKeyEvent(Unknown Source)
at java.awt.DefaultKeyboardFocusManager.preDispatchKeyEvent(Unknown Source)
at java.awt.DefaultKeyboardFocusManager.typeAheadAssertions(Unknown Source)
at java.awt.DefaultKeyboardFocusManager.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.access$200(Unknown Source)
at java.awt.EventQueue$3.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(Unknown Source)
at java.awt.EventQueue$4.run(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
javax.net.ssl.SSLHandshakeException: java.security.cert.CertificateException: Java couldn't trust Server
at sun.security.ssl.Alerts.getSSLException(Unknown Source)
at sun.security.ssl.SSLSocketImpl.fatal(Unknown Source)
at sun.security.ssl.Handshaker.fatalSE(Unknown Source)
Caused by: java.security.cert.CertificateException: Java couldn't trust Server
... 59 more
... 59 more
Trying for ASDM Version file; url = https://199.195.168.123/admin/
at sun.net.www.protocol.https.HttpsURLConnectionImpl.connect(Unknown Source)
at com.cisco.launcher.y.a(Unknown Source)
at com.cisco.launcher.y.if(Unknown Source)
at com.cisco.launcher.r.a(Unknown Source)
at com.cisco.launcher.s.do(Unknown Source)
at com.cisco.launcher.s.null(Unknown Source)
at com.cisco.launcher.s.access$000(Unknown Source)
at com.cisco.launcher.s$2.a(Unknown Source)
at com.cisco.launcher.g$2.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
... 21 more
Trying for IDM. url=https://199.195.168.123/idm/idm.jnlp/
at com.cisco.launcher.w.a(Unknown Source)
at com.cisco.launcher.s.for(Unknown Source)
... 19 more
Solved! Go to Solution.
02-20-2014 05:14 AM
There were several postings online. This may not be the best or only fix but this is what worked for me.
So here is the work-around that I used to resolve the issue.
1. Go to the ASA IP address in IE.
2. Select Continue to website. (This is where it asks if you want to install the ASDM Launcher)
3. In the Address Bar click on "Certificate Error" then "View Certificates."
4. Go to Details tab and select "Copy to File" and export the cert to my desktop using the default DER format.
5. Open Java Control Panel and go to "Security" tab and "Manage Certificates."
6. Selected "Secure Site" in drop down box and clicked "Import."
7. Select "All Files" in drop down box, and selected the Cert that I exported from IE.
Some of my customers told me that the “copy-to” button was grayed out, this is because the IP is not in the trusted zone.
Here is the fix for that if needed
Then use the webstart ASDM if all of the above fails. :-/
04-25-2017 01:18 AM
Thanks a lot John and Mitchell. Faced the same issue. Now it's clear.
02-24-2014 09:51 PM
Unfortunately, Java Webstart did not work with me, at least not before I added the ASA URL to the exception list of Java Control Panel.
Go to Java Control Panel, Security tab, then click Edit Site List, and add the URL of your ASA (https://ASAIPAddress)
04-30-2014 11:40 AM
08-11-2014 08:10 PM
I got the same issue and the solution is import SSL certificate of the ASA to Certificate Snap-in:
- Open https:\\asaipaddress
- Export certificate to ABC.cer (up to browsers)
- Start\Run => mmc
- File => Add\Remove Snapin
- Select Certificate \ Computer Account \ Local Computer
- Import ABC.cer to:
- Personal
- Trusted root certification authorities
- Intermediate certification authorities
- Done
08-12-2014 07:56 PM
Voquoclevi,
Thanks! I was able to follow you up to the point of importing the certificate to Personal Trusted and Intermediate. WHere do I get the cert to install? I don't recall the step to actually save a .cer file.
Thanks!
08-13-2014 04:38 PM
That's first step: Open web browser, browse to ASA address. And the way to export .CER file is based on each particular browser.
05-03-2016 12:47 PM
I'm sure there are more elegant solutions I could hack with, but....
Your solution to go through IE and add the security certificate worked, and just saved me literally hours of effort.
Thank you.
Paul
