ASR1002 boot issue after IOS downgrade
boldizsar
Dear All,
I have a problem with an ASR1002 (not X) ROM: IOS-XE ROMMON, but now, I can not boot it up.
I have tried to downgrade the IOS. Now I think I made a mistake, I guess the RP2 IOS is not right, I should have choose a RP1 IOS instead. But it is too late now.
Now the router is waiting for me to respond a “name1” , but I don’t know what should I type/choose.
Do you have any idea, please?
Please help me to boot it up somehow, I will much appreciate your help.
Many thanks,
Arpad
The factory IOS : asr1000rp1-adventerprisek9.03.13.02a.S.154-3.S2a-ext.bin
New IOS:               asr1000rp2-advipservicesk9_noli.03.13.01.S.154-3.S1-ext.bin
I have setup the boot order to this, this is in the running config now:
boot-start-marker
boot system flash bootflash:/asr1000rp2-advipservicesk9_noli.03.13.01.S.154-3.S1-ext.bin
boot system flash bootflash:/asr1000rp1-adventerprisek9.03.13.02a.S.154-3.S2a-ext.bin
boot-end-marker
At the moment the router always wants to boot from bootflash:/asr1000rp2-advipservicesk9_noli.03.13.01.S.154-3.S1-ext.bin
And causes the following result:
System Bootstrap, Version 15.3(3r)S, RELEASE SOFTWARE (fc1)
Copyright (c) 2013 by cisco Systems, Inc.
Current image running: Boot ROM1
Last reset cause: LocalSoft
Last reset at: Fri Oct 02 09:52:45 UTC 2015
ASR1002-RP1 platform with 4194303 Kbytes of main memory
Located asr1000rp2-advipservicesk9_noli.03.13.01.S.154-3.S1-ext.bin
Image size 632832260 inode num 14, bks cnt 154501 blk size 8*512
*** Data TLB Error Exception ***
PC = 0xffe70804, Vector = 0x1400, SP = 0x7ff3f8
CPU context of the most recent exception:
R0    = 0x4768fb4b R1    = 0x007ff3f8 R2     = 0xffe3ffe3 R3     = 0x00000000
R4    = 0x00000008 R5    = 0x007ff404 R6     = 0x007ff3d8 R7     = 0x00000000
R8    = 0x00000001 R9    = 0xc231b1e4 R10    = 0x00000001 R11    = 0x00000000
R12   = 0x00000001 R13   = 0x8000001c R14    = 0x100b27b4 R15    = 0x00000000
R16   = 0x102270a8 R17   = 0x100b3020 R18    = 0x100e0000 R19    = 0x100de9f4
R20   = 0xfbf00000 R21   = 0x00000000 R22    = 0x001ca2f9 R23    = 0x00000001
R24   = 0x00000200 R25   = 0x1dfec000 R26    = 0x1e009840 R27    = 0x00000200
R28   = 0x002b0000 R29   = 0x00000001 R30    = 0x00000004 R31    = 0x00000048
CR    = 0x40000004 LR    = 0xffe5d328 CTR    = 0xffe7ae0c XER    = 0x00000000
TBU   = 0x00000000 TBL   = 0x9e2da94b DEAR   = 0xc231b1f8 IVPR   = 0x00000000
PVR   = 0x00000000 DBCR0 = 0x00000000 DBCR1  = 0x00000000 DBCR2  = 0x00000000
IAC1  = 0x00000000 IAC2  = 0x00000000 DAC1   = 0x00000000 DAC2   = 0x00000000
CSRR0 = 0x00000000 CSRR1 = 0x00000000 MCSRR0 = 0x00000000 MCSRR1 = 0x00000000
PC    = 0xffe70804 MSR   = 0x02009200
usage:  name1 [name2 ...]
Here, it is waiting for me to respond a “name1” , but I don’t know what should I type/choose.
Option 2:
I’ve already tried to go to ROMMON and ignore the config and boot from a USB, but unfortunately that did not work for me.
It always wants to boot the wrong RP2 IOS from flash:
Setup to “ignore system config”:
rommon 1 > confreg
           Configuration Summary
   (Virtual Configuration Register: 0x2102)
enabled are:
[ 0 ] load rom after netboot fails
[ 1 ] console baud: 9600
boot: ...... image specified by the boot system commands or default to: cisco2-ASR1002-RP1
do you wish to change the configuration? y/n  [n]:  y
enable  "diagnostic mode"? y/n  [n]:  n
enable  "use net in IP bcast address"? y/n  [n]:
disable "load rom after netboot fails"? y/n  [n]:
enable  "use all zero broadcast"? y/n  [n]:
enable  "break/abort has effect"? y/n  [n]:
enable  "ignore system config info"? y/n  [n]:  y
change console baud rate? y/n  [n]:
change the boot characteristics? y/n  [n]:
   (Virtual Configuration Register: 0x2142)
enabled are:
[ 1 ] ignore system config info
[ 2 ] console baud: 9600
rommon 1 > boot usb0:/asr1000rp1-adventerprisek9.03.13.02a.S.154-3.S2a-ext.bin
Please reset before booting
rommon 2 > reset
Resetting .......
Result after “reset”, (still wants to boot from the wrong flash IOS):
Last reset at: Fri Oct 02 11:56:13 UTC 2015
MSCD_StartStop failure in usbflash_mscd_scsi_listener for usbflash0:!
#######################################################################################################################################################################################################################################################################################################################SATA drive PCI config error
Leo Laohoo
Of course it won't work.  The ASR has an RP1 but you're forcing the ASR to load an IOS meant for RP2 and this is why the router won't load the new IOS.
Thanks Leo.
Finally i have find a solution to my problem (setup a boot order in ROMMON which excepted by the router.) the solution is, to setup the confreg to 0x0 and follow the process below:
Perform the following steps:
1. Verify that the image file is present in the harddisk:, bootflash:, or external USB device (usb0: or usb1:) by using the dir file-system command at the rommon prompt.
2. When you run the dir file-systemcommand, if a message similar to "Please reset before continuing" is displayed, reconfigure the configuration-register to 0x0 and then run the reset command to allow the router to enter the rommon prompt without reattempting to boot using an invalid image.
rommon> dir harddisk:
Please reset before continuing <<<<<
rommon> confreg 0x0
rommon> reset
3. Boot the router from the rommon prompt by using a command similar to the following example:
rommon>BOOT=harddisk:asr1000rp1-ipbasek9.03.05.01.S.152-1.S1.bin
4. To save the current environment variable setting, run the synccommand as follows:
rommon> sync
5. Ensure that autoboot has been enabled by using the confreg 0x2102command at the rommon prompt, and then run the reset command at the same prompt.
Thanks a lot!!!
Thanks Mate
Right Procedure. *****
