VIP Collaborator
ASR1002X doesn't detect SAP card, OIR doesn't work
Hello community,
We are having the next problem: We are trying to add a new SPA (SPA-5X1GE-V2) by OIR, but the ASR doesn't detect the new card, it doesn't go up.
RTTMCPDCOR01#sh hw-module all fpd
H/W Field Programmable Current Min. Required
Slot Card Type Ver. Device: "ID-Name" Version Version
0/1 SPA-5X1GE-V2 1.4 1-GE I/O FPGA 1.10 1.10
0/2 SPA-4XOC3-POS-V2 2.0 1-I/O FPGA 1.1 1.1
RTTMCPDCOR01(config)#hw-module subslot 0/3 sh ununpowered
%subslot 0/3 not found
RTTMCPDCOR01#sh hw-module subslot all oir
Module Model Operational Status
subslot 0/0 6XGE-BUILT-IN ok
subslot 0/1 SPA-5X1GE-V2 ok
subslot 0/2 SPA-4XOC3-POS-V2 ok
RTTMCPDCOR01#sh hw-module subslot all sensors
SPA-5X1GE-V2[0/1] temperature sensor 0, reading: 25C
SPA-5X1GE-V2[0/1] temperature sensor 1, reading: 29C
SPA-5X1GE-V2[0/1] nominal: 3.300V, reading: 3.314V
SPA-5X1GE-V2[0/1] nominal: 2.500V, reading: 2.502V
SPA-5X1GE-V2[0/1] nominal: 1.500V, reading: 1.495V
SPA-5X1GE-V2[0/1] nominal: 1.200V, reading: 1.199V
SPA-4XOC3-POS-V2[0/2] temperature sensor 0, reading: 32C
SPA-4XOC3-POS-V2[0/2] temperature sensor 1, reading: 39C
SPA-4XOC3-POS-V2[0/2] temperature sensor 2, reading: 29C
SPA-4XOC3-POS-V2[0/2] nominal: 1.215V, reading: 1.220V
SPA-4XOC3-POS-V2[0/2] nominal: 2.520V, reading: 2.519V
SPA-4XOC3-POS-V2[0/2] nominal: 3.325V, reading: 3.325V
RTTMCPDCOR01#sh platform
Chassis type: ASR1002-X
Slot Type State Insert time (ago)
0 ASR1002-X ok 13w1d
0/0 6XGE-BUILT-IN ok 13w1d
0/1 SPA-5X1GE-V2 ok 13w1d
0/2 SPA-4XOC3-POS-V2 ok 13w1d
R0 ASR1002-X ok, active 13w1d
F0 ASR1002-X ok, active 13w1d
P0 ASR1002-PWR-AC ok 13w1d
P1 ASR1002-PWR-AC ok 13w1d
Slot CPLD Version Firmware Version
0 14012203 16.2(1r)
R0 14012203 16.2(1r)
F0 14012203 16.2(1r)
RTTMCPDCOR01(config)#no hw-module subslot 0/3 shutdown unpowered
RTTMCPDCOR01#sho upgrade fpd progress
% There is no FPD image upgrade in progress.
 Any help will be appreciated.
Best Regards,
Everyone's tags (3)
7 REPLIES 7
Advocate
Re: ASR1002X doesn't detect SAP card, OIR doesn't work
Highlighted
Hall of Fame Community Legend
Raise a TAC Case.  I believe this is CSCtd77202.
Participant
do you have the minimum ROM version to support this module?
chris
VIP Collaborator
Hello cmarva!
Thank you for your answer, which version is it? I didn't see anything about ROM version in the requiriments for OIR.
Best Regards,
Participant
there is a minimum ROMMON version for the module to be supported in the first place.
after re-reading the initial post, I do see in the output that you have ROMMON v16.2.1, and also that a like module is showing in place for 13 weeks, so I the ROMMON is not the problem.
At this point, I'd agree with Leo and suggest opening a case. You can look up the bug ID Leo provided and see if you're running an affected version, but even if you're running a version that is not listed, you could still be hitting it.
chris
VIP Collaborator
Ok Chris thank you,
I will open a case, when I have the answer to this problem I will let you know.
Thanks to everyone!
VIP Collaborator
Ok Chris thank you,
Thanks to everyone!
Everyone's tags (3)
Content for Community-Ad
July's Community Spotlight Awards
