Authenticate users when they connect for the first time to my network and assign them bandwith permissions and others.
HI everyone.
I need a solution that when you connect to my network via wireless or fiber, it asks the user to authenticate with a username and a password and then based on its account, will receive certain bandwith for a certain time and maybe other configs.
I'm quite lost here, i run a service provider with 100% cisco equipment.
What solution would you guys deploy?
Captain HoOmi
Beginner
Beginner
You need a combination of radius server and 802.1x implementation , i.e Cisco ISE
See here: https://www.cisco.com/c/en/us/td/docs/solutions/Enterprise/Security/TrustSec_1-99/Dot1X_Deployment/Dot1x_Dep_Guide.html
And here for switch configuration: https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/sec_usr_8021x/configuration/xe-3se/3850/sec-user-8021x-xe-3se-3850-book/config-ieee-802x-pba.html
** Please rate this post or accept the solution if it helped! :) **
Recognize Your Peers
