26026
Beginner
Auto clear ip dhcp conflict *?
Is there a command or config that will make a router automatically clear ip dhcp conflict * on a regular basis? I have a site that constantly has a problem with DHCP due to conflicts which is fixed simply by clearing the conflict table. If we could automate this, it would be great.
2 ACCEPTED SOLUTIONS
Hall of Fame Cisco Employee
Re: Auto clear ip dhcp conflict *?
You can use EEM for this.  This EEM applet will run the "clear ip dhcp conflict *" command every night at midnight.
event manager applet clear-dhcp-conflict
event timer cron cron-entry "0 0 * * *"
action 1.0 cli command "enable"
action 2.0 cli command "clear ip dhcp conflict *"
This assumes you have a release of IOS that supports EEM 2.1 or higher (which covers the majority of recent IOS releases).
No, it won't write a log message, but you could add one:
action 3.0 syslog msg "Cleared IP DHCP conflict records"
You can read more about EEM from http://www.cisco.com/go/eem .
9 REPLIES 9
Highlighted
Hall of Fame Guru
Jason
I suspect this could be done with EEM. The expert for this sort of thing usually answers questions in the Network Mangement forum so you should move this post there.
Jon
Beginner
Thank you. I moved it to Network Management, per your suggestion.
Beginner
I put the command in exactly as you wrote it. When it runs, will it leave an entry in the log?
Also, can you point me to beginner documentation on the event manager? It seems like it could be really useful.
Beginner
It works perfectly. Thanks for the help.
I modified your example to solve similar issue. I wanted it run every hour though. Here's how to modify Cron format:
https://en.wikipedia.org/wiki/Cron#Predefined_scheduling_definitions
My EEM simple script:
DV-CORE(config)#event manager applet ClearDHCP
DV-CORE(config-applet)#event timer cron cron-entry "0 * * * *"
DV-CORE(config-applet)#action 1.0 cli command "enable"
DV-CORE(config-applet)#action 2.0 cli command "clear ip dhcp conflict *"
DV-CORE(config-applet)#action 3.0 cli command "clear ip dhcp binding *"
Hi, what is the meaning of this below line
can u plz give some example of "time" instead of zero 0 0  and * * starts.
this can help me to understand what actually this command do.
Enthusiast
Hello
You can use  ip dhcp conflict resolution
Content for Community-Ad
July's Community Spotlight Awards
