Automatic archive configuration
Hello everybody!
I have simple but annoying problem - i'm trying to implement archive command but my devices don't do any automatic configuration backup. When i hit "archive config" or  "write mem" it backups configuration perfectly, but after that nothing happens. Here is part of configuration:
archive
path tftp://10.13.0.28/wwwwwwwwwwwwwww
write-memory
time-period 1
Thanks in advance
tkatsiaounis
Beginner
Beginner
You should use kron (yeah like Linux cron) to execute write memory command and then the archive config you have will send the write memory output to the ftp server. So it is going to be like
archive
write-memory
kron occurrence Backup at 13:15 Wed recurring
policy-list Backup
kron policy-list Backup
cli write
Another thing you can consider is using a tool like Rancid (linux based and free) which not only archives your configuration automatically but it also keeps versions and you can check any changes.
tkatsiaounis
Beginner
Beginner
archive
write-memory
policy-list Backup
cli write
Splendid! Thank you!
Recognize Your Peers
