Automatic BACKUP on NEXUS 3k
geevee1989
Hi All,
I have written the below script for NEXUS 3K but it wont work since my 3K doesn't support watchdog feature. is there any workaround for this to work?
Also please let me know if there are any mistakes in the script
event manager applet backup
 event timer watchdog time 86400
 action 1.0 cli command "enable"
 action 2.0 info type routername
 action 3.0 cli command "copy run tftp:///$_info_routername"
 action 4.0 cli command "" pattern "vrf"
 action 5.0 cli command ""
Geevee
Ashok Kumar
CRON timer can do the same thing what you're with watchdog timer.
Below are tutorial link which will help you in applying the CRON in EEM.
http://networkengineering.stackexchange.com/questions/3473/time-based-interface-shutdown-on-cisco-router
http://www.rogerperkin.co.uk/ccie/eem-2/understanding-cisco-eem-event-timer-cron/
- Ashok
Please rate the post or mark as correct answer as it will help others looking for similar information
Thanks Ashok but unfortunately my Nexus 3k does not support kron
any other options?
 Geevee
jkilleda
Level 3
Level 3
Hello Geevee,
Watchdog doesn't work in Nexus (NX-OS) the workaround would be that you can set scheduler in it .
Working config: N3K-C3172TQ-10GT - username and folder. Without password. VRF - is optional.
scheduler job name backup-config
copy running-config ftp://N3K-C3172TQ-10GT@192.168.1.100/$(SWITCHNAME)-conf.$(TIMESTAMP) vrf LAN
end-job
scheduler schedule name backup-config
  time start 2018:06:29:16:58 repeat 7:0:0
Just take into account that automation backup on Nexus 3k possible only with tftp file transfer or with ftp without password.
