Highlighted
Beginner
Automatic port shutdown on 3650 switches
Hi guys,
I am searching for a solution for an automated port shutdown on 3650 switches. Ports should be shut if a specific IP destination is no longer reachable to power off some PoE devices.
I thought I could easily resolve this with ip sla with event manager to shut the port and no-shut back when the destination is back up but the event track sub command of event manager applet is missing. I assume it is unsupported on that platform.
Any ideas for a solution?
jay
7 REPLIES 7
Highlighted
VIP Expert
Can you post-show version.
also is this feasible out of the box do this for you like, send the ping results to Syslog server, Syslog server login to switch and shut down the port? (this is only offered as a suggestion, since you mentioned event track not available)
BB
*** Rate All Helpful Responses ***
Highlighted
I tried it on different 3650s, here's the output of the latest:
sh ver
Cisco IOS XE Software, Version 16.12.03a
Cisco IOS Software [Gibraltar], Catalyst L3 Switch Software (CAT3K_CAA-UNIVERSALK9-M), Version 16.12.3a, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2020 by Cisco Systems, Inc.
Compiled Tue 28-Apr-20 09:25 by mcpre
Good idea to build a workaround like you suggested but syslog servers are management by other team so thinks are getting complex :D
Any further suggestion?
Thank you
Highlighted
post complete output of show version
BB
Highlighted
Here we go:
show ver
Cisco IOS-XE software, Copyright (c) 2005-2020 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
BOOTLDR: CAT3K_CAA Boot Loader (CAT3K_CAA-HBOOT-M) Version 3.56, RELEASE SOFTWARE (P)
tw-tp-sw02 uptime is 4 weeks, 4 days, 20 hours, 35 minutes
Uptime for this control processor is 4 weeks, 4 days, 20 hours, 38 minutes
System returned to ROM by Reload Command at 13:16:11 CEST Fri Jun 12 2020
System restarted at 13:20:24 CEST Fri Jun 12 2020
System image file is "flash:packages.conf"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Technology Package License Information:
Technology-package Technology-package
Current Type Next reboot
ipbasek9 Smart License ipbasek9
None Subscription Smart License None
Smart Licensing Status: REGISTERED/AUTHORIZED
cisco WS-C3650-24PS (MIPS) processor (revision S0) with 795156K/6147K bytes of memory.
Processor board ID FDO22123456
2 Virtual Ethernet interfaces
56 Gigabit Ethernet interfaces
2048K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
252000K bytes of Crash Files at crashinfo:.
252000K bytes of Crash Files at crashinfo-2:.
1611414K bytes of Flash at flash:.
1611414K bytes of Flash at flash-2:.
0K bytes of WebUI ODM Files at webui:.
Base Ethernet MAC Address : 78:0c:f0:aa:cc:00
Motherboard Assembly Number : 73-15899-07
Motherboard Serial Number : FDO22123456
Model Revision Number : S0
Motherboard Revision Number : A0
Model Number : WS-C3650-24PS
System Serial Number : FDO22123456
Switch Ports Model SW Version SW Image Mode
* 1 28 WS-C3650-24PS 16.12.3a CAT3K_CAA-UNIVERSALK9 INSTALL
2 28 WS-C3650-24PS 16.12.3a CAT3K_CAA-UNIVERSALK9 INSTALL
Switch 02
Switch uptime : 4 weeks, 4 days, 20 hours, 39 minutes
Base Ethernet MAC Address : 00:2a:10:aa:bb:00
Motherboard Assembly Number : 73-15899-06
Motherboard Serial Number : FDO20987123
Model Revision Number : N0
System Serial Number : FDO20987123
Last reload reason : Reload Command
Configuration register is 0x102
Highlighted
unfortunately, you have "ipbasek9" which has a limited feature. you need to uplift the license to have your requirement or go with the suggestion to make it easy(whichever feasible for your business).
BB
Highlighted
You mean it works with ipservices?
Highlighted
you need right version for the features to work.
BB
Content for Community-Ad
