AVC /Medianet / NBAR not supported on (cat4500es8-UNIVERSALK9-M) ?
amine haddanou
Beginner
Beginner
hi;
i execute the configuration ,but I still have some worries.
the AVC /Medianet / NBAR not shown in the dashbord interface on NetFlow Analyzer ,how to enabel this features .
SW-4507RE-CEV# show version
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch  Software (cat4500es8-UNIVERSALK9-M), Version 03.06.04.E RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Sat 13-Feb-16 12:30 by prod_rel_team
Cisco IOS-XE software, Copyright (c) 2005-2015 by cisco Systems, Inc.
All rights reserved.  Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0.  The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY.  You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.
(http://www.gnu.org/licenses/gpl-2.0.html) For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: 15.1(1r)SG5
SW-4507RE-CEV uptime is 4 years, 11 weeks, 6 days, 3 hours, 10 minutes
Uptime for this control processor is 4 years, 11 weeks, 6 days, 3 hours, 12 minutes
System returned to ROM by reload
System restarted at 13:01:14 UTC Sat Oct 29 2016
System image file is "bootflash:cat4500es8-universalk9.SPA.03.06.04.E.152-2.E4.bin"
Jawa Revision 3, RadTrooper Revision 0x0.0x41, Conan Revision 0x1449
this is VSS Environment
flow record RecordNFA
match ipv4 tos
match ipv4 protocol
match ipv4 source address
match ipv4 destination address
match transport source-port
match transport destination-port
match interface input
collect interface output
collect counter bytes
collect counter packets
collect timestamp sys-uptime first
collect timestamp sys-uptime last
flow exporter ExportNFA
destination xxxxxxxxx
source Vlanxxx
transport udp 9996
template data timeout 60
flow monitor MonitorNFA
exporter ExportNFA
cache timeout active 60
record RecordNFA
Thanks and Regards,
hi ;
thank you so much ;
marce1000
 Ref : Feature navigator - Check attached document, feature does not seem to be available on the platform that you mention.
 M.
-- ' 'Good body every evening' ' this sentence was once spotted on a logo at the entrance of a Weight Watchers Club !
hi ;
thank you so much ;
