10-17-2014 07:41 AM
Hi, all.
I actually have a router with sub-ifs...
I want to monitor the bandwidth with PRTG on each sub-if at the same time using Netflow.
I managed to make this configuration, but until now only accepts one sub-if each time.
Here is what I have on the router:
flow exporter PRTG
description FLOW_EXPORTER_TO_PRTG
destination 10.10.10.10
source GigabitEthernet0/1.1
transport udp 1000
export-protocol netflow-v5
interface GigabitEthernet0/1.1
encapsulation dot1Q 1
ip address <IP-ADDRESS> <MASK>
ip nbar protocol-discovery ipv4
ip flow ingress
ip flow egress
ip flow-export source GigabitEthernet0/1.1
ip flow-export version 5
ip flow-export destination 10.10.10.10 1000
This only works if I add the commands in red.
I created a new flow exporter, e.g.>
flow exporter PRTG_2
description FLOW_EXPORTER_TO_PRTG_2
source GigabitEthernet0/1.2
transport udp 1000
And configured on the sub-if
interface GigabitEthernet0/1.2
ip flow ingress
ip flow egress
But, on the PRTG it doesnt import/receive the flow.
Because of the source command in RED above.
I use show ip flow and this is what it shows>
Router#sh ip flow export
Flow export v5 is enabled for main cache
Export source and destination details :
VRF ID : Default
Source(1) <IP-ADDRESS> (GigabitEthernet0/1.1)
Destination(1) 10.10.10.10 (1000)
Version 5 flow records
50914209 flows exported in 1697147 udp datagrams
0 flows failed due to lack of export packet
0 export packets were sent up to process level
0 export packets were dropped due to no fib
0 export packets were dropped due to adjacency issues
0 export packets were dropped due to fragmentation failures
0 export packets were dropped due to encapsulation fixup failures
Router#
Am I doing something wrong here?
Is there a way to activate the SOURCE simultaneosly?
P.S.: Without the commands in red it doesnt work.
P.S. 2: I tried to use the interface and not the sub-if
Any help?
Warm regards
/EV
Solved! Go to Solution.
10-19-2014 01:35 PM
Dear Edson
The red lines which you added are legacy netflow commands. First you used NFN ( Flexible NetFlow). These are separate things and their operations do not correspond each other.
About NFN:
You created Flow Exporter but missed the next step. You must enable flow monitor to complete your configuration; here's an example
flow exporter PRTG
source 192.168.1.1
destination 10.10.10.2
transport udp 500
flow monitor MONITOR1
record netflow ipv4 original-input
exporter PRTG
interface Ethernet 0/0
ip flow monitor MONITOR1 input
10-19-2014 01:35 PM
Dear Edson
About NFN:
flow exporter PRTG
source 192.168.1.1
transport udp 500
exporter PRTG
10-20-2014 01:57 AM
Thanks for you reply...
It worked just fine.
Thanks.
But on the flow exporter config, it didn't allow me to use:
source <IP Address>
Only the interface...So I used the interface and it worked.
Here is what it allows me:
Router(config)#flow exporter PRTG
Router(config-flow-exporter)#source ?
Async Async interface
Auto-Template Auto-Template interface
BVI Bridge-Group Virtual Interface
CDMA-Ix CDMA Ix interface
CTunnel CTunnel interface
Dialer Dialer interface
Embedded-Service-Engine cisco embedded service engine module
GigabitEthernet GigabitEthernet IEEE 802.3z
Group-Async Async Group interface
LongReachEthernet Long-Reach Ethernet interface
Loopback Loopback interface
MFR Multilink Frame Relay bundle interface
Multilink Multilink-group interface
Null Null interface
Port-channel Ethernet Channel of interfaces
Tunnel Tunnel interface
Vif PGM Multicast Host interface
Virtual-PPP Virtual PPP interface
Virtual-Template Virtual Template interface
Virtual-TokenRing Virtual TokenRing
vmi Virtual Multipoint Interface
Few questions:
1. Can I use the "original-output" on the same flow monitor?
So, putting something like (check red):
flow monitor MONITOR_PRTG
exporter PRTG
record netflow ipv4 original-output
2. On the interfaces Im monitoring, I left like this:
ip flow ingress
ip flow egress
ip flow monitor MONITOR_ENH input
Using the flow monitor, do I have to keep or remove the red commands above?
3. On the interface below for example, can I use the input with output at the same time?
Or the "input" itself works?
ip flow ingress
ip flow egress
Thanks again for your reply.
/EV
10-20-2014 02:58 AM
Q1- There's no limitation for using input and output simultaneously.
Q2- "ip flow egress/ingress" monitor old net flow command (ip flow-export) and are not related with your new configuration, "remove them".
Q3- using record input/output or both of them is up to you and what do you want to measure on interface.
Good luck
