03-30-2020 07:54 AM - edited 03-30-2020 09:13 AM
So I configured this Net Monitoring tool and I added all ports(mostly access layer/user ports/FEX) from all devices we have, and they are at 2400 in total right now, is that normal? Do I have to monitor each port? or should I just monitor the transit links/Uplinks/device health only???!
What is the best practice out there to monitor everything or to just monitor the crucial parts?
Thank you so much
03-30-2020 08:34 AM
https://www.paessler.com/manuals/prtg/recommended_sensors
M.
03-30-2020 11:21 AM
So thanks for the comment, but this is not about a particular software,
say we have a campus consisted of 5 gigantic high rises, should we monitor every single port?
idk the best practice regarding that honestly...
03-31-2020 12:42 AM
- There is no unique answer to that question. It will be different per organisation requirements, usually you will monitor the backbone network and links, including redundancy. User-port status depend on importance of attached servers, but then application monitoring is more useful because they will far earlier signal problems before a server is hard-down, if that happens at all when an application hangs.
M.
