Best practice for choosing how many sensors you need
George-Sl
So I configured this Net Monitoring tool and I added all ports(mostly access layer/user ports/FEX) from all devices we have, and they are at 2400 in total right now, is that normal? Do I have to monitor each port? or should I just monitor the transit links/Uplinks/device health only???!
What is the best practice out there to monitor everything or to just monitor the crucial parts?
Thank you so much
marce1000
  https://www.paessler.com/manuals/prtg/recommended_sensors
M.
So thanks for the comment, but this is not about a particular software,
say we have a campus consisted of 5 gigantic high rises, should we monitor every single port?
idk the best practice regarding that honestly...
          - There is no unique answer to that question. It will be different per organisation requirements, usually you will monitor the backbone network and  links, including redundancy. User-port status depend on importance of attached servers,  but then application monitoring is more useful because they will far earlier signal problems before a server is hard-down, if that happens at all when an application hangs.
 M.
