SATORU SAEGUSA
Beginner
BFD on Nexus 5500 Series
Hi, all.
Can a failure of Layer 3 GEM or Layer 3 daughter card expansion module be detected by BFD feature? I understand that Nexus 5500 switches can not directly and continuously monitored normalcy of the expansion modules. When the expansion modules lost layer 3 forwarding capability, am I able to notice it by BFD?
Thank you for your cooperation in advance.
1 REPLY 1
jkilleda
Participant
Hello SATORU,
You can use BFD to detect forwarding path failures at a uniform rate, rather than at variable rates for different protocol hello mechanisms
